What should i do when i start self cleaning the oven & i see flames?
SOURCE: Whirlpool Gold Accubake self-cleaning gas oven door lock solenoid
i think there is some kind of shorting somewhere.
SOURCE: Whirlpool gas oven-Super Capacity 465
When you turned the oven off, if the ignitor went off and the gas kept flowing then the thermal valve is defective. Maybe that was the problem all along.
SOURCE: whirlpool accubake oven will not heat after self clean cycle
I had the exact same thing...thermostat..
SOURCE: when i turn my oven on, the flames come up into
If the burner pressure is adjustable(some are not) you can use a small adjustable wrench to turn the gas orfice to lower the gas pressure. The orfice is usually located in the broiler/storage comaprtment at the very bottom of the range. It is the brass piece that goes into the burner venturri and is where the gas comes out. If your turn it clockwise it will decrease pressure & counter clockwise will increase pressure. If the flames are coming into the burner compartment that is quite an increase in pressure!!! Make sure the the range did not have the gas regulator removed. If it was then that would explain why the oven burner pressure is so high.
SOURCE: My oven flame is yellow and orange. you can smell
open air vent on main burner. check burner orifice and pressure regulater
