20 Most Recent Whirlpool Accubake RF362LXTT Electric Kitchen Range Questions & Answers
2answers
My smooth cook top is cracked, can I still use the burners?
using a cracked cooktop is highly dangerous. i have seen these cooktops shatter because of people using them with a crack. One shattered so bad that the glass was found all over the kitchen and the ajoining living room.
Please dont use it, for your safety, repair or replaced the unit
8/2/2022 11:39:57 AM • Whirlpool... • Answered on Aug 02, 2022
The Lock feature doesn't work (Whirlpool Accubake
Hi Stephen, that lock button locks the controls so settings can't be changed or oven started accidentally. Try putting the unit into self clean and see if that locks the door. If not it show an error code on the display telling you if there's a failed component. Give it try hopefully that will do the trick.
5/4/2017 8:12:14 PM • Whirlpool... • Answered on May 04, 2017
Cant get the timer for self cleaning to turn off
Try to pull out the plug, when the oven is cool, try to open the door.
7/3/2015 11:28:18 PM • Whirlpool... • Answered on Jul 03, 2015
How do I get the door back on when there are no hinge locks or pins?
The hinges usually just slide in and drop into the lock position. Align both hinges with the cavity on either side and push the hinges and door until they go inside.
3/20/2015 5:05:31 AM • Whirlpool... • Answered on Mar 20, 2015
A code pops up on my oven e5 f2 what dose that mean
Hello Danny; My name is Peter. I am a retired field service appliance technician. F2-E5 - Cancel Key Line Open - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly. You have left the last number off your model number. If it is '0': 25369211-kdkppxbie4yi2ig501kzn0pg-5-0.jpg PART NUMBER: W10114377 Cost: $241.00 If you elect to replace the control board, make sure when you receive the new board in a anti-static gray bag, ground yourself by rubbing your hands on something that is bare steel. Static electricity will knock out a board. The price provided is from Sears Direct. You can get the same part on E-bay for $110.00. Rule of Thumb: "If the cost of repair is 1/3 or greater than the original purchase price, then buy new." You have a older but nice unit. Peter Goodwin Glen Burnie, MD 443-306-1362
1/16/2015 9:44:56 PM • Whirlpool... • Answered on Jan 16, 2015
The code E5 F2 comes up on the control panel ,what dose that mean .
1/16/2015 9:32:28 PM • Whirlpool... • Answered on Jan 16, 2015
0answers
I have no power to oven or burners. Where are the fuses located
there would be no fuses in the stove itself. Try the house breaker or fuses to the stove.
9/28/2014 8:14:22 PM • Whirlpool... • Answered on Sep 28, 2014
I spilled a lot of bacon grease in my accubake oven when i turned the self cleaner on it flamed
Wipe out the oven with paper towels. As much as you can. Try putting some baking powder down to absorb the grease then wipe it out. If the flames are not huge it should be ok. Mine did that once and burned out the grease and did not damage the oven, but they were very small and burned down quickly.
8/10/2014 4:51:33 PM • Whirlpool... • Answered on Aug 10, 2014
Whirlpool accubake
Almost all electric stoves vent the oven through a hole in either the back right or rear burner. They can get very hot. I am surprised that your control panel is burned. It is only dangerous if you place a combustible over the burner. I have had some people do this and it has melted it. i haven'y heard of a fire from this but it could happen if it was hot enough.
8/1/2014 4:11:36 AM • Whirlpool... • Answered on Aug 01, 2014
My oven and stove top isn't working at all. If I
I was having this problem and it was because I had tripped the breaker. Reset the breaker (box Inside your home) and try that, However, there is probably an underlying electrical problem that should be fixed asap. I live in an older remodeled mobile home that isn't equipped to handle a lot of appliances going at the same time. Try to make sure you aren't pulling so much power when you use the stove, ex: TV, microwave, oven, stove, all running at the same time.
5/22/2014 11:31:53 PM • Whirlpool... • Answered on May 22, 2014
0answers
0answers
0f cal message
Be the first to answer 1/7/2014 3:48:16 AM • Whirlpool... • Posted on Jan 07, 2014Be the first to answer
Broken glass oven door stove inner 050551136
12/24/2013 12:48:01 AM • Whirlpool... • Answered on Dec 24, 2013
When I turn on My Whirlpool Accubake Gas Oven, it will ignite and heat up to the tempurature set, but it wont sustain the heat properly and cool down. If I restart it, it will reheat, but still not s
Yes, you can fix this yourself very easily. You need a new temp. sensor. Here is the part to order. There is also a video on that same parts page to show you how to make the repair. Keep me posted!
12/11/2013 12:52:44 AM • Whirlpool... • Answered on Dec 11, 2013
Kenmore code F1 and broil wont go off
he clock on my STOVE started flashing F1
  • You have either a bad ERC (clock) or a bad touch pad.
    1. Disconnect power to stove
    2. Gain access to the back of the clock (electronic range control or ERC).
    3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
    4. Make sure everything is clear and will not short out when power is turned back on.
    5. Turn power back on to stove.
    6. Watch for the F1 and listen for the beep.
    7. If you get the F1 and beep, replace the ERC.
    8. If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.NOTE: Some models incorporate the touch pad and the clock as one part.
Here is the part to order.All parts come with a 365 day, any part, any reason return policy.
10/26/2013 1:14:33 AM • Whirlpool... • Answered on Oct 26, 2013
Whirlpool Accubake RF362LXTT Electric Kitchen Range Logo
144 questions posted
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Kitchen Ranges
Most Popular Question
kenmore code f1 broil wont go off
  • Kitchen Ranges
