you added stabil but did you run the gas out of the carb? Take the carb apart and klean all with carb cleaner, spray in all holes. Check the plug gap of the new plug while your into the unit anyway the gap should only be 1mm. Dennis
Hello there and thank you for choosing fixya normally on these when you dont recieve a spark and you are 100% sure that the spark plug is good than the only thing left to check is the ignition coil It is what the plug wire is connected to kind of a square or round part these are nortorious for going out in small engines this is a 35 dollar part ok? thee if this does not do it check the on off switch for continuity Then finaly Check the flywheel cover, the magneto gap and starter coil if there's still no spark.
Read more: How to Troubleshoot a Small Gas Engine Trimmer ' eHow.comhttp://www.ehow.com/how_6306856_troubleshoot-small-gas-engine-trimmer.html#ixzz1LrUTc28o
