Ericsson T202g Gpon Sbu Voice, Data, And E1 Internet Broadband Switch Eda1500 Logo
e
emmalee Posted on Aug 08, 2014
Does any UA5000 can work with any version U2000? I want to know the version, please!
candytang
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Aug 08, 2014
candytang
Contributor
Level 1:
New Friend:
Answers
21
Questions
21
Helped
3838
Points
55
No, it has some restrictions:
1.V100R017 matched the U2000 V100R002C00 and later version.
2.V100R019C00 matched the U2000 V100R002C00 and later version.
3.V100R019C01 matched the U2000 V100R003C00 and later version.
4.V100R019C07 matched the U2000 V200R001C00 and later version
For the specific information, you can log in
UA5000 Huawei HONET UA5000 Price and Specs Huawei DSLAM UA5000...
Why is an error message displayed when the MA5800 is added to the U2000?
The U2000 V200R014C60 and later versions support the MA5800. It is recommended that you use the NMS version matched with the MA5800 version.
Why is an error message displayed when the MA5800 X15 is added to the U2000?
U2000 and later version the MA5800 X15. It is recommended that you use the NMS number matched with the MA5800 version.
How do I factory reset a MA5608T where I don't have a working username / password or have it setup in U2000?
If you want to reset all the settings on Huawei MA5608T to the factory settings, you can erase flash data like below:
MA5608T(diagnose)%%erase
{ flash<K> }:flash
{ data<K>'language<K> }:data
If you just want to reset only the user and password, you can undo terminal user name.
2answers
How to change a rectifier on a U2000 floor buffer?
The rectifier is in the top end of the motor. Take the cover off and then the top end plate of the motor. With the bolts removed, you will have to tap and rock the plate to evenly remove it. Carefully look at the marks on the old and new part to be shur you do not make a mistake in the wiring. A drawing and photo might be nice too.
How to verify the success of UA5000 hairpin connection configuration
Handling Process
A:Run the command display esl online-info all to check the DSP resource occupation: huawei(config)#display esl online-info all ------------------------------------------------------------------------------ UserPort DSPPort Codec PT EC VAD Gain(I/O) Duration(hh:mm:ss) Urgent ------------------------------------------------------------------------------ ------------------------------------------------------------------------------The call does not occupy the DSP resources, which indicates that the configuration of hairpin connection service is successful.
Root Cause
1. For subscriber A and B in the same MG, the hairpin connection is to connect the timeslots of subscribers A and B on the network chip for the call between A and B. 2. The hairpin connection service does not occupy the DSP and bandwidth resources.
Suggestions
Alternatively, you may capture packets and check whether there are RTP streams sent to destinations beyond the MG. However, the above method is simpler.
Huawei DSLAM
Huawei MA5616
How to connect the PTH, SDH, OLT AND ONU?
The current technology in PTN direction development, Huawei PTN packet switching network, SDH (synchronous digital system), the ONU is PON (passive optical network) in the concept, the ONU is lower.Access layer is commonly by hosting online travels.OLT, ONU is through the PTN, Ethernet, etc., belongs to the category of the access layer, and should be OLT, mainly VOIP access, with your said, the concept of SDH transmission, so OLT, are all belong to the category of transmission bearing networkThe current technology in PTN direction development, PTNPTN () packet switching network, SDH (synchronous digital system), the ONU is PON (passive optical network) in the concept, the ONU is lower.Access layer is commonly by hosting online travels.Huawei OLT, ONU is through the PTN, Ethernet, etc., belongs to the category of the access layer, and should be OLT, mainly VOIP access, with your said, the concept of SDH transmission, so OLT, are all belong to the category of transmission bearing network
Nov 09, 2015 • Cell Phones
Top Ericsson Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Ericsson Electrical Supply Expert? Answer questions, earn points and help others
