Hi! Your vacuum is most likely not picking up because of a clog, dirty filter or worn belt or a combination of the three. Please try these trouble shooting steps below.
1. Check that the brushes are still spinning. If not replace the belt.
2. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the hose.
3. Remove the dirt cup. Remove the red baffle tube by rotating 1/4 turn counter-clockwise. Clear the baffle tube of any hair or debris. Replace the baffle tube.
4. Remove the filter from vacuum base. Hold filter under running water to rinse. Allow 24 hours to air dry before replacing.
Hope this helps get your vacuum back up and running!
