On a chest freezer, frost always accumulates around the top perimeter first because the warmer moist air comes in contact with that area first once the door is opened. More frequent defrosting may be the answer.
5.5 Cu. Ft. Chest Freezer
Click to Enlarge
Lowest price:$179.00Description: Food
storage will be a snap with this roomy 5.5 cu. ft. chest freezer,
featuring up-front temperature control, storage basket and defrost water
drain.
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
The reason this happens is because the defrost timer is not turning back on when it needs to, causing the freezer to thou out and overfill the drip tray sitting on top of the compressor.
A new defrost timer should be available from the local refrigeration wholesalers in your area.
