SOURCE: oven cuts off
turn off breaker to oven pull stove out and check incoming power supply, possible looseconnection at that point
SOURCE: electric stove top and oven
Welcome to fixya.
Range does not heat (lights and timer do not operate).
This would indicate the
range is not receiving the required 220 volts. Check house hold
breakers or fuses, open wiring between the terminal block and the
components, and the power cord.
Please remember to leave a rating before you leave
SOURCE: Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
SOURCE: Stove Top won't heat
clock works because its only 110 volts.all else is 220.as a repair man the firstplace i would check is the cord.[power off]why there first the installers dont know how important it is for those cord screws to be very tight.consequintly the leave them looseish,and thats where they burn.if thats ok.make sure you have 220 there at the cord.God bless you,tom
Hello Friend, this is Z. Thank you for your post! I see you are having trouble with both your burners and oven not working. Can you remember any error codes or any odd functions prior to this issue? Also, may you provide me you model number please. You can normally find the serial tag (which lists your model number) in the storage drawer, on the right side. With this information I can better address the issue at hand. Thank you!
