Microwave Ovens Logo
A
Anonymous Posted on Jul 09, 2014
Inches to cubic feet
Would a cooler that is 27.5 x 16.75 x 19.063 inches go into car which has 34.3 cubic feet available in the trunk? thanks
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Master 102,366 Answers
  • Posted on Oct 23, 2014
Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444354
Points
622693
The cooler is about 5.08 cubic feet. it may or may not fit depending on the shape of the trunk.
What does 1.1 cubic ft equal in regular inches?
1.1 (cubic feet) = 1 900.8 cubic inches - that is length x depth x height... could be 1 inch by 1 inch by 1900 inches high (unlikely)... but that would still be 1.1 cu ft... or 12 inches by 12 inches by 13.2 inches... and so on
2answers
15x14x9=how many cubic feet?
Square feet is calculated L x W so 10x10 would be 100 sq. feet, Cubic feet is calculated by L x W x H so 15 x 14 x 9 = 1890 cubic feet
WHAT IS THE CUBIC FEET OF JVM1339WB-002 GE MICROWAVE SPACE SAVER?
Determining the cubic feet of any given appliance, Microwave, Oven, Freezer or Refrigerator is quite simple.
Follow these steps.
Open the door of your microwave and measure the length, width and height in inches of the interior cavity.
Multiply the length by the width by the height using a calculator to get the total in cubic inches.
Divide the cubic inches by 1,728, which is the volume of a cubic foot. The resulting number will be your microwave's measurement in cubic feet. You can also use an online conversion calculator to simplify matters
Hope that helps
1.8 cubic feet is how many inches
1.8 cubic feet is 3110.4 cubic inches.
About 9.17 cubic feet.
48 inches by 48 inches by 48 inches is 110,592 cubic inches.
Convert cubic inches to cubic feet
Since there are 12 inches in a foot, there are 12x12x12 or 1728 cubic inches in a cubic foot.
Dividing 1404.4921 by 1728 gives about 0.8128 cubic feet.
1helpful
We have the GE JVM130H 001 microwave. I am trying to figure out what is the cubic feet capacity of this microwave. Can anyone tell me?
Hi, W/D here.
Here's an easy way to calculate your cubic feet: measure and multiply (in inches) the width X depth X height, then divide by 1728. This will give you cubic feet.
For example, if a microwave measured 18" wide X 18" deep X 12" high, it would be 3888 cubic inches; divided by 1728 (cubic inches in one cubic foot) = 2.25 cu.ft.
Best regards, --W/D--
Please take a moment to rate this solution. Thanks. --W/D--
Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
12inches
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
