Check your user name..even tho it says the password is incorrect.. I had the same problem and it was an incorrect user name being used which of course throws up the password error. Try using the full yahoo mail address.
Precor Error 15, AC Input Voltage Too High
Probable Cause
1. AC input voltage is incorrect.
2. AC input voltage transients. Transients can be caused by lightning strikes or by other pieces of equipment sharing the unit's AC power.
Corrective Action
Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
Ensure the AC grounding for the unit's outlet is good and verify the unit is connected to an isolated and dedicated 20 amp circuit.
The 50300 error code is the result of incorrectly inputting network connection information.
This means that your network name (SSID), WEP/WPA/WPA2 key, or manual settings you have entered could be incorrect. I suggest that you go back and re-enter those settings.
If all of your entered details are correct, your network may require you to use the "Manual Setup" option on the Wii.
The 1102 error code means that the login user name is incorrect or the domain name has not been entered. You may need to reneter the login user name, domain name and password.
ERROR CODE (80710092) can mean incorrect password, incorrect user name or bad internet connection check your user name and password and if that doesn't work then disconnect your ps3 from the internet and then reconnect
Error
Code: 206401
This error indicates
that the Club Nintendo user name or password is incorrect or invalid.
Verify that your Club Nintendo user name and password
are being entered correctly.
If this is your first time accessing the Wii Shop Channel,
verify that you're not hitting "Link" with the fields blank (if you
don't have a Club Nintendo membership, you need to select "Do not
link").
Make sure you are connecting to the database,then just before you call your sql to insert use an echo statement to display the sql and check it for syntax:-
$sql = 'insert into table1 values('.$no.','.$no.',"block","'.$value3.'", "'.$value4.'")'; echo "SQL ==>" STARTOFSQL<br>".$sql." ENDOFSQL<br>";
