SOURCE: We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
SOURCE: 1988 true GDM 33 its 100+deg. in my shop.
The unit is probably not designed to work in an ambient temp that high, probably 90-95 would be as hot as the manufacturer was thinking, however the age of this unit probably means the compressor valves are not sealing quite as well as they used to. this can cause a unit to never pull down all the way to proper temp. get as much air circulating to the unit to help draw heat away
