Will not reverse
SOURCE: i HAVE A DEWALT DC729 18V DRILL
is this a north american model.all i can find is model DC727 & DC728 model. charger model 9116 & battery is DC9096 may work.charger volts 110v ac. if your buying the individual part like batt & chgr its more expensive than buying the whole kit is cheaper. hope i answer your question
SOURCE: Dewalt battery charger
You will need he correct charger, the 24V will destry a very expensive battery.
SOURCE: problem with the chuck
Had the same problem on mine. Remove the chuck, then remove the snap ring on the back of the chuck( carefull, the housing will fall out once the ring is removed), on the side of the chuck you'll find a cam and small odd shaped spring held in by two cylender pins, on mine the spring had a gap in it and I just spread the gap to about twice the size in was and put everything back together and it has worked fine ever sence. Hope it works for you.
SOURCE: Holding battery charge on 12v DeWalt batteries
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
