Expert
- Posted on Feb 03, 2017
Re: How to fix broken dinosaur?
Make sure your battery compartment has no signs of corrosion. If it does use a corrosion cleaner solution that can be used for cars to clean it off. The wires are small on these toys which means it could be a broken thin little wire too. If that's the case, solder them back together. Good luck!
Cruncher was working but slowing down so I replaced the batteries, correctly, I checked. After I put the battery cover on it would not turn on anymore. He is dead.i think maybe the on off switch isn't connecting anymore. There appears to be a circuit under the on off switch but I can't get to it.
mattel said they do not service him
or sell parts.
