GE JVM1650 1000 Watts Microwave Oven Logo
A
Anonymous Posted on Jun 15, 2014
Do microwaves have fuses
I have a ge jvm1650wh05 space saver microwave,it turns on and all that but does not heat anything could it be a fuse?
4 Related Answers
Anonymous
  • 126 Answers
  • Posted on Apr 22, 2009
SOURCE: Ge Microwave space saver over range working but
It is a good possibility that the stirrer has failed. In the top of cabinet is a round cover,there is a small round plug in the edge of it,pry plug out and put it in safe place,rotate the cover < twist locks > gently let it down and stirrer will be either setting on cover or still attached. If you notice any damage< it is a round aluminum disc that is flat > then you need a new one. If you don't see any damage put it back in < put in hole and turn until you feel it line up with shaft and push into place,< gently >.Make note of position and put cover back on < stirrer does not lock on shaft so you have to hold it up until you get cover under it in most cases. Run a short cycle and remove cover to see if it turned at all. If not the motor is bad < turns stirrer during operation>. This is the first time that question has been asked of me and it is the only thing that I can think of if it heats glass and not food.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Feb 10, 2010
SOURCE: GE JVM130K004 space saver microwave not working
The magnetron is overheating, and the magnetron thermostat is tripping, interrupting power until it cools back down.
This is to protect the magnetron from being destroyed from overheating.
It may be that the internal cooling is not occurring or the magnetron is failing. Cooling can be compromised by:
- failed or failing internal cooling fan
- blocked air inlet or filter
- outer cover not installed correctly
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At
our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Testimonial: "Thank you -I decided to replace the mic. By the time I pay $75 just to send someone out, + labor & parts to repair I found a replacement GE for $199"
Anonymous
  • 43501 Answers
  • Posted on Sep 30, 2010
SOURCE: GE space saver Microwave not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Anonymous
  • 43501 Answers
SOURCE: my microwave is not heating, and the table is not turning.
heatman101
76t
My space saver microwave will not heat anything yet everything else works.
i found on my micro setting if i accidentally set it up for convection, it stays that way and therefore just heats slowly when I think i'm microwaving. i have to re set it after i use convection or it defaults to that and therefore will not heat / microwave.
Microwave will not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
l'l'l'l'l'l'l'l'l'l'l'l'
WE have a JVM1650SHO5 space saver GE Microwave Oven that suddenly started not heating. No other issues.
heatman101
My microwave is not heating, and the table is not turning.
heatman101
76t
Where is fuse in space saver microwave
The link below will take you to a diagram of your microwave. The fuse is item #47.
http://www.partselect.com/MultiModels.aspx?ModelNum=JVM1640SJ&searchTerm=&RefineSearch=0
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
heatman101
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
2answers
Microwave GE Spacemaker (JVM130K004) needing access to fuse
Yeah, I posted a question on FixYa and that did it --- you know they seem to really want to solve your problem --- and don't syphon your knowledge just to sell to others later.
Thanks.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
