If you have an Elite 5x then it is not a combo unit
If it is a combo them the small door about the power button with the model number on it swings open.
A micro SD card goes in there. If your chart is an SD not a micro you will find the micro is in the end of the big car. Pull it out and pop it into the unit.
hi, it means that the brake is giving the incorrect resistance , this can be because of a faulty micro-switch or simply a bad connection to the controller so worth checking ..
Please note : i offer a free controller and brake testing , you only pay return postage ..
Usually if it beeps 5 times on this model,I have found that either replacing the micro-switch at the brake assy is malfunctioning.You can either choose to have this micro switch replaced or bypass the switch by connecting the 2 wires together that go to & from the switch itself.Hope this helps. There is also a troubleshooting guide in your owners manual in regards to the number of beeps & the cause.. Barry ([email protected])
Not beeing an expert on these machines, owner of one that had brake troubles that I fixed, it sounds like the micro-switch on the brake assy. is not functioning, either due to miss adjustment (as mine) or failed switch. ronnell33.
Try downloading and running Spyware Terminator and Spybot Search & Destroy. Both can be downloaded from PC World for free. Be sure to update each program before you scan. If you want to try an online scan, try Trend Micro Housecall, which is free..
Hi.. usually there is a "CODE" key on the keyboard. This is to be held down while pushing the pitch key (10 -12- 15) may say Pica-Elite-Micro. On some models there is a actual switch to move to the 10-12-etc. I hope this is helpful and solves your Problem. Squipps
