20 Most Recent
Pride Mobility Products GoGo Ultra X (3wheel) Questions & Answers
Battries fully charged, turn key on and only beeps 5 times. Thats all.
hi Hal, that is a issue around based the brake or connectors to the brake or the micro-switch that is moved when you move the drive , freewheel lever.. ... firstly make sure the scooter is in drive mode and not free-wheel mode ., where the axle comes apart you will see a number of connectors , make sure they are a good fit ...
Update me please...
Regards
Rob
Why won't my scooter freewheel?
If the brake release lever is not working by this I mean the lever will not move the release position, this could be a case of the brake mechanism has seized up due to water or that sand and grit has got in the brake jamming it.
Try a spray of WD40 on the bake lever mechanism and work the lever back and forth. Failing that brake will need to be replaced.
Troubleshooting code beeps 9 times. battery is charged and the unit is not hot.
hi, okay that a system controller fault however it can also be a loose connection around the controller area, removing the connectors that go into the controller has worked for me, if not it's normally a resistor network inside the controller.
I offer a free testing and repair service ...
Regards
Rob
www.gewizrepairs.co.uk
Scooter beeping
Six beeps would say it is the throttle pot not in its centre off position or the pot needs replacing. Is the wig wag lever loose by this I mean the lever is wobbly and moves up and down a fair bit. This would indicate its had its day. Have you had speed issues before this problem as this is normally the case before they go wrong altogether.
Battery recharge
Well If the scooter has been sitting without use since 2011 then you cannot recharge them you'll have to replace them they would be dean at tis point.
Scooter beeps but will not go
Make sure it is placed in gear, sounds like it is in the Neutral free wheel position.
If the scooter moves easy when you push it, it's just in free wheel.
Wiring diagram on a gogo scooter
The wiring interconnects on these scooter are all modular and the blow up assembly diagrams are all you need to trace the wiring and replace components. Aside from a dealer log in to the manufacturer's website you can go to southwest medical's website and get all the information on the wiring and parts. Hope this helps.
SC40X Go Go Ultra Replacement Parts
Go go ultra
hi, okay if it's the loading effect on the batteries, not a loose connection, then look at the speed pot, when it slows down try pushing the lever upwards or downwards, improves then the pot needs replacing , this is a simple test to see whether the tracks within the pots are worn...
Regards
Rob
How to take appart the rear section
9 flash code usually happens when the battery connection is interrupted while the key switch is turned on. On Go Go Ultra series, there is a spring loaded terminal post that the battery box sits on to make the connection. Sometimes as this spring wears out, the connection will be interrupted then reconnect again while driving causing the 9 flash code. try putting a nickel on each of these battery connections underneath the battery box and see if that fixes the problem. If you do need to take the shroud off, flip on it's side, there are 4 small bolts that bolt the shroud to the frame from the bottom side. they're easily visible. Hope this helps.
Reset switch
hi , that could be a faulty reset switch, I come back later and give you a more complete reply as i run out of time now.RegardsGeWiz
Hello my problem is that
sounds to me like you have a bad cell in the battery. i would try a new one. if this is new it may be under warrenty. remember just because somethings new dosent guarentee it works properly. if you get a new battery and the same thing happens it could be a charging problem or short with the chair.. i hope this helps you
