Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kenmore model by clicking the link below.
https://www.searspartsdirect.com/partsdirect/user-manuals/11092822102-kenmore-parts-manual
You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/appliances
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
SOURCE: need manuals
What problem are you having, the problems i have seen with kenmore elites are below.
1. when you press start and release dryer shuts off
for this problem, change the board in the console
2. not producing heat
for this problem, check to see if 220 is getting to element, check to see if you are getting 220 from outlet, check your thermal cutoff on heating housing, check your heater relay which is located in top console.
SOURCE: Error message F44 in a Kenmore Elite Dryer. What
F-44 indicates a faulty blower motor controller. $169.00 from sears
or about $115.00 from an appliance parts store. Also note: the
service technicians repair guide is usually folded and tucked inside the top of the dryer console. It contains all the F codes and disassemble and reassemble and testing instructions. Part # for the service guide is (W10035270).
SOURCE: How do I prep my Kenmore Elite He5t washer for move to new house
Washers n dryers usually require some balancing after a move to the new area, and when you lift the washer on a dolly, you lift it from the rear. Assuming you've already tipped the washer slighlty to one side, checked the bottom for which side has the most metal underneath. This is best done with 2 people. Do the same with the dryer. The braces are used to help balance or to keep from tipping when the machine was packed inside a large box.
SOURCE: just inherited a kenmore elite oasis dryer model 110 77092600
Go to Sears and buy it! You cheap B.
searspartsdirect.com - and enter your model #.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
