It does not make any difference to the sound whether I mute the fx or not. Cannot get any echo or reverb.
SOURCE: I have an mackie cfx 12 on which the effects do
Yes, send this to a Makie repair facility. Chaances are there is a chip going bad... most likely the A-D or D-a convertor.
Try putting this is your freezer and then immediately test it. This MIGHT indicate if problem is easily found with circuit cooler spray.
SOURCE: The mute button cuts the main audio but the effects audio is still heard. What to do?
That's basically normal actually...however it depends on which aux send you're using. If you use aux 1 for the effects, you can use the pre/post switch on the master aux 1 send to switch it to pst fader....now your mute switch should kill the effects as well. Aux 2 is good to use for monitors where you don't need to return them to the mixer.
