Try to restart the printer once or twice....after that check if the printhead is moving to the center of the printer or not. if its moving to the center...try to take out the printhead and then reseat it back in the printer. this will fix the problem for you.
feel free to contact if this doesn't fix ur problem.
SOURCE: kodak 5300 first said error 3802 now says print head missing or loose
I got the same Problem as listed above. This is the way how I was able to solve it:
Hope this solves the Problem. Best wishes
SOURCE: kodak 5500 printer can't detect print head
open the cover and take out the printheads and clean the contact points. also clean the contact points on the printer.
reinstall it and see what it does,also try turning the printer off and on /
if this does not work you need a new printer /the printer hardware is bad for sure if you have already replaced the printhead and catridge .
if printer is in warranty ask for a replacement
SOURCE: The printer says that my print head is loose or
First thing to do is get the top off which can be easier said than done. The printer has four screws holding the top. After that remove the control panel by undoing the four screws holding it in place. This isn't strictly necessary but it makes life easier. Now move the print head to the left. To do this you have to lower a locking bar that is located at the base of the head. The head can be quite hard to move but it does slide left. Under the print heads you will find two pads of hard foam. These collect the ink when you perform a normal head clean and keep the print head moist. Soak these with water . Pool water on them and let it run through (it goes through to a large pad at the bottom of the machine by the way). Fold some tissue and lay it on the base when the heads pass over. Push the head back and forth over the tissue to clean the actual head. The tissue will come out covered in ink.Now for the tricky part get an old printer cartridge and remove the label on top that says "do not remove". Under the label you will find a couple of holes. Widen them / open them with a drill bit about 3 mm is good. Fill the cartridge with water and put it in the printer. Push the heads back over to the right as far as they will go. This will cause the sponges to come right up against the heads. Leave the set up over night. In the morning test the printer. Run a couple of head cleans with the cleaning cartridge in. Your problem is solved now
Thank you!
