I've tried the putty knife and it opens @ 1/4 inch then stops. pls help
Many of the newer washing machines lock when in use. Does your machine resume washing when the door is shut again?
Actually you don't. you remove the 2 screws on the back of the control panel and you pull the control panel forward and up. Disconnect the wire harness,then you will see 2 clips. One on each side of the top. Use a screw driver to remove them and the whole body can be lifted towards the front and removed.
