This error code has three main reasons. First of all toner spilling occured and the two sensor that detect toner bottle are dirty and should be cleaned, also form the toner hoper that rotate the toenr is defective and should be changed or developer material should be changed. In my experince clean the two sensor that detect the toner and change the developer material and the code will not show it is the most efective way of dealing with this error.
you might want to unplug the set and plug it back, my list does not show a code or error code 66 for this set. Power it up and let it fail and check for the error, if the wrong model was posted here that may be the reason.
CODE 66: "Open or short circuit of steering damper solenoid lead." Check the ESD fuse has not blown first befoe checking the wiring itself. CODE 70: This model is equipped with an engine auto-stop system. The engine stops automatically if left idling for 20 minutes.In this case, the multi-function meter indicates error code 70, but this is not a malfunction.Push the start switch to clear the error code and to restart the engine. Hope this helps
To determine thage of your appliance you need to have the serial number also.
Check out this tip from another expert and compare your serial number to find the age of your fridge.
try these 2 sites, i believe they have some good info you need and will probably solve your issue. ive heard some horror stories about norton. unistall and see what comes about. it seems as though too many connections are going to screw this item up and norton will do the same.
On my Casio Ddigital Camera the lens comes out when I press the open button but then it shows LENS ERROR and shuts down again. Please advise what the problem could be. Thank you.
