My Facebook app keeps crashing, it will come on but goes out in secs.
Assuming this app is on an iOS device (Apple). Following these Several steps should resolve your issue, firstly quit the app entirely by using four fingers swipe up on the tablet, or press the home button twice, either step will show the active apps, find the Facebook app, then with a single finger swipe up, this step should see the app move upwards on the screen, quitting the app. Theis next step requires you to hold the power button and the home button at the same time, until the device shutsdown and the logo appears, then let go of both buttons allowing the device to start/boot completely. Locate your Facebook app, start it, does the problem still exist? If after the above steps you still have the same issue, you can delete the app, by placing your finger over the app & holding until the app jiggles and shows an "x" in the top left corner of the app graphic, touching the "x" will remove the app from your device, you can then re-install the app, finally you may simply need to check to see if the app needs to be updated, by opening the AppStore, and selecting Updates, if an update for Facebook is available for you it will show up here. I hope something within the information has helped.
Hi Jennifer DeLong, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
