I added too much oil and now the plug keeps fouling
SOURCE: Pressure Washer problem
If it has the same good compression it did when new, replacing the carb will probably fix your problems. Be real sure about the compression, an engine with low compression and a funky carb might just as well get replaced.
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
