I have a technics sa-gx500 receiver that I love . had it in storage for a couple of years now it has no sound coming out of the speaker outputs.. turns on fine just no sound .. any thoughts ?
SOURCE: Receiver amp problem?
You are having problems with you audio amps, 1 or more are going out. will need to change using part number on amps. you can order from, Bluestar-online.***, VanceBaldwin.***
SOURCE: Technics SA-DA10 Receiver-no sound
Most of these problems are rooted in a failed power amp module.
I'm working on an older technics unit but with the same troubles.
SOURCE: Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Testimonial: "worked like a champ!"
