the problem is not in your video recorder than to your video cassette, the Underside of the tape on the left side needs to have a little plastic, if it does, then put a little sticky tape insulating {}, because without it you can not to record it ..... . if after this no records should then take video recorder repair service ....... Good luck ....
It's on the back edge of any VHS video tape, it looks like a square piece of plastic which is only attached at one side. Break it off and the VCR can't record on the tape. Cover the hole with sticky tape to record again. If your looking for the tab inside the machine just see where the loaded video lands. Most video tapes with it removed will go into automatic play when there's no tab. Also the VCR will eject the tape if any attemp is made to record on a protected tape.
One possibilty is the record sensor that pushes against the tab on the video tape (the bit you break off to prevent a tape being recorded on) has bent out of shape and the video therefore thinks ALL tapes are pre-recorded or protected and rejects them.
Since it is playing the tape, the play head is ok. Now recording is done by recording heads so you may have a clogged heads or damaged recording heads. Try to clean the heads with head cleaning tape to see if it would help. 1. remove the tape and leave the door open. 2. using a canned air, blow out any dusts in the tape area. 3. run head cleaning tape for about 10 seconds and no more. 4. try the recording.. If this does not resolve, you may have a damaged or heavy clogged video heads. Take it to nearest video technician for a diagnostic. -James
Dont use xp mode. Here are the definitions: SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video. LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video. EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder] OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
This is probably caused by an irregular magnetic encoding pattern being generated by the tape itself. If the DVD recorder does not fully recognise the code, it may incorrectly interpret it as copy protected. If there is any tape flutter or there are tape edits, these can contribute to the problem. In addition to this magnetic imprinting can occur on old tapes that have been stored for a number of years without being spooled. basically wrong bits of the tape get magnetised. You can sometimes hear an echo on old tape recordings caused by imprinting.
You could try the following:
1) If available, try using a different video machine to play back and record from.
2) Whatever video machine you use, put your tape in, fully fast forward and rewind a couple of times, then try your recording again. This is particularly important if you haven't used the tape for some time.
3) If it fails again, check to see if it always fails at the same point.
4) If it does, try winding forward a little and then try to resume recording.
5) If you can record it means that a short section of tape is giving a spurious code to your dvd recorder and confusing it.
6) Use a re-recordable dvdrw to make a master. You won't keep wasting discs if the recording stops. You will also be able to produce another dvd from your master and edit it if your recording ends up in a number of segments.
7) Always use the highest quality setting possible when producing a master.
8) If all else fails, if you have a friend with another dvd recorder, maybe try that.
put tape on the hole on top of the tapes and you shoud be able to record. its tape on the top or pull the top off i cant remimber which one it is but this is the answer.
