SOURCE: i have a 2002 yz 250, it wont start, i just found
if the wire is long enough then solder it.but if the wire is torn out of the cdi box then you need to buy a new one.
SOURCE: 98 YZ 250 started sputtering at higher rpms?
just change the plug buddy use a br8eg and get back to me if still not starting
SOURCE: would a cdi box cause
Not likely. would cause it to not run. you if this is a 2 stroke you may need to adjust your oil mixture. manual says 30;1 But 40:1 is much better.
SOURCE: Need a ignition wiring diagram for a 1999 yamaha
http://www.4shared.com/document/sMjNLzGr/2003_Yamaha_YZ250_FR_Wiring_Di.html
The link above is the wiring diagram from the 2003 Yamaha YZ250, but I am not sure if this will match the 1999 Yamaha YZ250.
Here is a link to the 1999 Yamaha YZ250 Service Manual, with the wiring diagrams: http://www.powersportresource.com/details.php?mID=237
It is less than $10.00, making it a great deal if the diagram I provided you doesn't match up.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: the yz 250 1986 has the same engine as the tri z
im not that good with carborators so any help will be great .
