Intel DG31PR Motherboard Logo
i
imran Posted on May 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not work keyboaed ps2 & usb - Intel DG31PR Motherboard
steyr1
Level 2:
  • Expert 148 Answers
  • Posted on May 10, 2014
steyr1
Expert
Level 2:
Answers
148
Questions
Helped
85474
Points
450
Try another keyboard first, second reset bios in factory value, third flash bios with a new release, if this isn't working .... throw your mb.
James Miller
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Intel Master 2,226 Answers
  • Posted on May 09, 2014
James Miller
Intel Master
Level 3:
Renaissance:
Answers
2226
Questions
0
Helped
447568
Points
2985
Try a new one or see if your driver are installed
Why won't my Logitech Traackman MArble FX work with Windows 7?
If you are trying to convert your Logitech Trackman Marble FX from PS2 to USB so it will work with Windows 7, you can't just convert the port type - you have to get an "adapter" that converts the PS2 signal to a USB signal. See for ATen - UC 100KMA. WEB SIte:
http://www.aten.com/products/KVM/KVM-Modules-&-Accessories/PS2-to-USB-Adapter~UC100KMA.html#.U5sYrCi4NAE.
It allows you to convert a PS2 keyboard and PS2 mouse/trackball with the one device. It's what I use and it works just fine. The regular $2.00 port adapter was useless.
They are on EBAY sometimes for $20 or so. GOOD LUCK. :)
W7 using dongle ps2 to usb
Supermicro SuperServer 5013G-M - PS2 error
Hello here is the homepage:
http://www.supermicro.com/products/system/1u/5013/sys-5013g-m.cfm
Is your Mouse a USB mouse or is it a HYBRID Mouse? Look at the bottom of mouse and see what is written. It should give you the: (1-) Name (2-) Model Number & it will either say: "USB Mouse" or "USB 2.0 and PS2 Compatible". If it is USB 2.0 and PS2 Compatible, then it is a HYBRID MOUSE - You should have a - USB to PS2 - Adapter that came with the mouse.
Use that adapter and plug into the PS2 Mouse port - (only if it is a HYBRID). It will automatically configure itself as a PS2 mouse. Now you will have both your Input devices set as PS2.
(2) - If it is a USB mouse, can you obtain a PS2 mouse to temporarily use? If you can; try using the PS2 Mouse Port?
Now you may have to set BIOS on - with regard to:
(1) - Legacy USB Support -(Either Support or Disable)
(2) - USB settings to what Motherboard supports
Try also to upgrade the drivers/bios, if nessesary.
SET LEGACY USB SUPPORT TO "DISABLED" FOR BOTH MOUSE & KEYBOARD IN BIOS.
Good luck
2answers
I cant use symbol ls2208ap . how i use it
hello, once you have it connected to your computer via usb, serial or keyboard wedge, you scan the barcodes that come in the user guide to set it up, its pretty much a plug and play. you can find the quick start guide at
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201cpdf&sliceId=&dialogID=165478796&stateId=1%200%20165462678
Let me know if i can be of additional assistance,
Kim Ganoe
800.933.2839 x251
Key board not detected ,message on booting f1 to contunue
You could try and swap the keyboard usb connector to another usb connector, if its a ps2 connection then check in the bios that it is enabled, it should be by default.
Also if you don't have a converter from ps2-usb go & obtain one & you should be fine, assuming your keyboards ok.
3answers
USB Keyboard and mouse wont work with PS2 KVM with adapter
Have you tried rebooting once it is connected? Not sure if it makes a difference, but I know you can not hook up PS2 peripherals without rebooting.
Bought new desktop but key board and monitor is not working.?
Did you plug the keyboaed & mouse in befor or after you trun on the PC?
Mx3200 keyboard stoped typing
Unplug the USB (or PS/2) plug for a couple of seconds and reconnect them. That worked for me when this happened on my older Logitech keyboard.
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
