SOURCE: Gigabyte GA 81845 GVM 775 Soundcard drivers
Hi try this link:-
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1930
It has all the drivers you need for your motherboard.
Hope this helps.
SOURCE: Gigabyte GA-8VM800PMD-775 @ 1.5gb memory
http://america.giga-byte.com/FileList/Manual/motherboard_manual_ga-8vm800pmd-775_e.pdf
Before installing the memory modules, please comply with the following conditions:
1. Please make sure that the memory used is supported by the motherboard. It is
recommended that memory of similar capacity, specifications and brand be used.
2. Before installing or removing memory modules, please make sure that the computer
power is switched off to prevent hardware damage.
3. Memory modules have a foolproof insertion design. A memory module can be installed
in only one direction. If you are unable to insert the module, please switch the direction.
1-4 Installation of Memory
The motherboard supports DDR II memory modules, whereby BIOS will automatically detect memory
capacity and specifications. Memory modules are designed so that they can be inserted only in one
direction. The memory capacity used can differ with each slot.
SOURCE: ECS Motherboard P4M800 LGA 775 Socket
One of these should work:
1. Reset the BIOS (remove mobo battery or short-out the two reset pins near the battery or CMOS chip)
2. Disconnect every drive from power and data; remove all add-on cards. Leave only video card and one memory module in place. Turn on.
I hope #1 worked for you.
In #2, a device may be internally shorted to ground, that's why you must disconnect the power AND data cables from them.
SOURCE: where can i find the drivers for my motherboard
Oh fun fun! When you start the board, enter the BIOS and see what model it is from. Usually on the big DELL screen (post) it will say "dimension" and etc at the bottom. jot that down and search support.dell.com for drivers. If all else fails, Enter the bios and look for the service tag. jot that tag down, then visit dell website, and search for that service tag. that should get you where you want to be.
SOURCE: how to disable graphic card ingigabyte g41
I am assuming you mean the on board grafic's card? if you are boot the computer up when you see f12 to boot to bios boot to bios then go to video card and turn off or disable the video card from bios then click F10 to save changes VGA mode so you can at least see the video. here is the web site for more help if you need it.
http://www.gigabyte.com.tw/Products/Motherboard/Default.aspx
