20 Most Recent MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard (7592-030R) Questions & Answers
I have had a motherboard failure the MS-7357
the ms, 7xyz series is a relic all that matters is the size of mobo, to case ATX or microATX some or most cases (not oem) do both sizes and none told by you case , maker and model but just looking there under mobo shows what screw stub holes are there for both. or not. the power switch is just 2 pins and easy to rewire. the manual on both cover all that but no case told.
5/23/2022 3:47:20 PM • MSI G41TM-E43... • Answered on May 23, 2022
Audio bus driver
Go to the intel site. They have these audio drivers for all intel motherboards.
3/17/2014 5:13:09 PM • MSI G41TM-E43... • Answered on Mar 17, 2014
No DVI signal on G41TM-E43
Download the driver from here:http://www.msi.com/product/mb/G41TM-E43.html#/?div=Driver&os=Win7%2064Please select your windows system 32 or 64 bit.Download the vga driver and unzip the file.Uninstall the old one before you install the new.Check also your bios for the graphic settings.My advice is to buy a better graphic card to insert in the pci-e socket instead of using the onboard graphic for better performance.Good luck
11/6/2012 1:08:08 AM • MSI G41TM-E43... • Answered on Nov 06, 2012
I have a Windows 7 Media Center PC, connected to
Set the resulation proper ,
If you need more information, reply me soon.
Thanks
2/20/2011 5:23:27 PM • MSI G41TM-E43... • Answered on Feb 20, 2011
2answers
Hi: from: [email protected] please help. my new msi
Hello thanks for asking,there are several reasons that can cause this problem,you should try plug your computer into a different wall outlet the present one may have a fault,{2) you can try using a different power cable the one use can be faulty,(3) you can check the connections to the motherboard tho make sure they are correct , the power connector and the 4 pin connector which power the CPU. Try these solutions and let me know if any work
7/22/2010 11:21:37 PM • MSI G41TM-E43... • Answered on Jul 22, 2010
Q: If the onboard video is having problem
yes...only u have to install the dat device's driver
3/18/2010 9:48:22 AM • MSI G41TM-E43... • Answered on Mar 18, 2010
Powers up no video and mouse stays lit when powers
This is an old motherboard, with this in mind there are a couple things for you to try. Power off the system and unplug the power cable from the power supply. Remove the left side of you're case. Touch any metal surface to discharge possible static.
First clear the cmos jumper on the motherboard. See page 1-17 in you're manual for the location of the cmos battery and cmos jumper. Also see page 1-21 to clear / reset the cmos battery. (Don't forget to set the jumper back to normal after 30 seconds.
Doing this will reset the bios to its default setting.
If you added a graphics card to one of the PCI slots remove it.
(For now).
Re-connect the power cord for the power supply and power-on the system. If the motherboards built in VGA controller is working you should have display on your monitor and since we cleared the cmos the bios will want you to enter the bios to adjust all its settings.
If you do not have display than the onboard controller is defective. You can add a PCI video card into any one of the 3 (White in color PCI slots). It’s not uncommon for the mouse to stay lit. If you're mouse is plugged into a PS-2 port try un-plugging it when the system is off.
Then re-connect it with the system off. You can also buy a USB to PS-2 adapter. Most new mice and keyboards come with this type of adapter. See the link provided; http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=776087&CatId=469
If you're mouse and keyboard are PS-2 and connects to the system by USB, try another opened USB port. The next link opends to Biostar and you're motherboard;
http://www.biostar.com.tw/app/en/mb/content.php?S_ID=324
Cheers'
Mike
3/9/2010 3:47:56 AM • MSI G41TM-E43... • Answered on Mar 09, 2010
G41tm-e43 + windows 7:
just install ur orignal window 7 driver for ur motherboard
http://www.msi.com/index.php?func=proddesc&prod_no=1791
follow this link
3/7/2010 7:37:27 AM • MSI G41TM-E43... • Answered on Mar 07, 2010
New build turned on power no beeps no video
make sure that your little speaker is plugged in to the correct pins. This gets many people every time. If the speaker isn't plugged into the correct slot you're definitely not going to get anything to work...yeah i know...a silly speaker...you can have quite a few things plugged incorrectly and things will still work but if you have the speaker plugged into the wrong one...then ur dead in the water...find the little cylindrical speaker and try plugging it into a different slot...really look on that board for it. Should be labeled JFP2..connect the speaker to the 4 pin side of that 7 pin connection.
12/21/2009 3:10:38 PM • MSI G41TM-E43... • Answered on Dec 21, 2009
2answers
How do i download MSI N082 graphics driver
To get the MSI N082 graphics driver: 1. Find your graphics card model. Note down the model number. 2. Go to MSI's website. 3. Look for the support or downloads tab and click on it. 4. Use the search or menu options to find drivers for your specific graphics card model. 5. Download the driver package. 6. Run the installer file once the download is complete.
3/26/2024 10:36:50 PM • MSI Computers &... • Answered on Mar 26, 2024
Screen does not fit after adjusting the screen resolution msi N082 i tried updating the VGA driver online but it keeps telling me that driver is up to date
If adjusting the screen resolution didn't resolve the issue and you've already updated the VGA driver, try manually adjusting the display settings through your computer's control panel or display settings menu. Look for options like overscan or scaling to ensure the screen fits properly. If the issue persists, it could be a hardware problem or compatibility issue with your monitor. Consider reaching out to MSI support for further assistance.
3/26/2024 12:50:33 PM • MSI Computers &... • Answered on Mar 26, 2024
How do i connect my fire stick thru bluetooth on my MSI windows 11 laptop??
To connect your Amazon Fire Stick to your MSI Windows 11 laptop via Bluetooth, you will need to follow these steps:
  1. On your Fire Stick, go to Settings > Display & Sounds > Enable Bluetooth.
  2. On your MSI Windows 11 laptop, go to the Windows Settings > Devices > Bluetooth & other devices.
  3. Turn on Bluetooth on your laptop and make sure that it is in pairing mode.
  4. On your Fire Stick, select your laptop from the list of available devices.
  5. On your laptop, click "Pair" when prompted to complete the pairing process.
  6. Once connected, you should be able to stream content from your Fire Stick to your laptop.
1/20/2023 11:59:27 PM • MSI Computers &... • Answered on Jan 20, 2023
Wanting to connect an older AV received to my Win 10 PC via optical input. Should I use MB or Graphics output?
You should use the audio output on your computer that is labeled as "optical" or "S/PDIF" (Sony/Philips Digital Interface Format) to connect to the optical input on your AV receiver. This will typically be labeled as the "digital audio out" or "digital output" on your computer. The "graphics output" is used for video, not audio.
1/12/2023 2:39:40 PM • MSI Computers &... • Answered on Jan 12, 2023
How can i enter the bios on my pc.
Proper training and equipment are needed to modify the (Basic Input Output System ) BIOS on a PC. You could turn your PC into a paper weight. The game has been criticized for its anti-cheat software, Vanguard, as it was revealed to run on akerneldriver, which allows access to the computer system.[56]OSNewsexpressed concern that Riot Games and its owner, Chinese technology conglomerateTencent, could spy on players and that the kernel driver could be potentially exploited by third parties.[56]However, Riot Games stated that the driver does not send any information back to them, and launched abug bounty programto offer rewards for reports that demonstrate vulnerabilities with the software.[57][58]The bounty will reward white hat hackers between $25,000 to $100,000 for reports on its vulnerabilities, with the pay being based off the severity of the exploit.[59]Gameplay bugs do not qualify for this bounty.[59] Valorantwill not run onWindows 11if the system does not have aTrusted Platform Module(TPM) 2.0 compliantcryptoprocessorandUEFI secure bootenabled, as mandated by Microsoft's minimum system requirements for the operating system.[60]
11/20/2022 7:19:17 PM • MSI Computers &... • Answered on Nov 20, 2022
Replacing an msi laptop screen
no PC told at all MSI is maker only but yes they all unplug on laptops(is it) they are held on by tricky ways and if forced you break mobo or display there are the easy ones push on pull off the the wedge locked, , unlocked first. and last the hinge lock FFC cable ends learn not to force them, look first for locks, 2/3rs of them are locked.
8/22/2022 8:33:42 PM • MSI Computers &... • Answered on Aug 22, 2022
I need the MSI MS7506 AMD AM2 Bios bin file
Contact AMD.
8/1/2022 10:43:59 PM • MSI Computers &... • Answered on Aug 01, 2022
I was using Sony
the reason you get lost is using bummer APPSlike nero or worst. doget Imgburn , free and safe and solid.use test mode.the do a test mode burnit now tells you exactly what fails. (sure does)and this is why, sure is.(filenames too long or?)"I know some units require a specific brand of blank CD" this is not really true.no player or burner has ODD media restrictions on brand. (ODD disk are really PnP disks that have ID track that tells the host what the disk can do, in every possible way)sure there are vast brands that are pure trash sure.just like tires car or the like. BRAND WISE.like old Firestonedeathtires. (cured by new owners)The Imgburn does fail on bogus medialet me explain, gee seen it all I havethe china import CD-r. has the ID track all configured illegallly, is invalid. so the burner warns of that pronto.a blessing that, like :::: illegall(sic), disk size or makers name missing or the burn limits stated are missing (useless hard nut fail here)a burner can not burn lacking this key ID track set correctly by the maker ( a must be good thing)a classic case of pure junk CD-r or DV-R or BD-Rtry TDK and verbatum and end this junk grade folly.
6/14/2022 3:45:01 PM • MSI Computers &... • Answered on Jun 14, 2022
The first of four led lights FLASH ON and 0FF ON A970-G46 MOB AND MY POWEER SUPPLY TESTS GOOD. All componets work good on my 2nd identical MSI MOB. CAN THIS MOB BE FIXED OR MUST I REPLACE IT?
four led lights where are they? lost the manual? Desktop mobo. MS-7693 (v2.x) Manboard 970a or 970S? all led x4 status indicators. on mobo top 4 glow means phase 4 power level. page 32. coin cell dead is #1 for all PCs over 5 year and for sure 7. a dead mobo, bios screens dead, that it,???? what gpu card what monitor ? all fans dead? support for vista or w7 , so that? bios HOT KEY IS <del> THEN F11 (BIOS II)? 2 MOBO 1 GOOD 1 BAD USING SAME CPU AND 1 STICK OF RAM.? same PSU>? wired same to mobo? THIS MOBA HAS NO VGA IGPU PORT ON REAR SO MUST HAVE GPU CARD or there can be video ever. and see bios. and reset bios first and new coin cell first. 7years old that coin is and will be a pain now or soon. a $ 1 fix. gpu card into top x16 slot????? GPU card over 75watts must have gpu aux power wired to it or it will be dead, from PCl. psu wired to JPWR2 ? must be. and JPWR1 both. or cpu will be dead. that is about it , on this 2011 mobo. no gpu card top in fact full speck on all things connected to the mobo no told, including all devices all cables, and cards. and port. not told.
5/23/2022 4:34:28 PM • MSI Computers &... • Answered on May 23, 2022
Can't enter bios (MSI 870AG46) the puter boots and runs the RAID setup and displays the 5 options, after exiting it skips the BIOS setup screen.
NO OS TOLD AT all and want help<. really? I will guess w7 ! Bios hot key is <del> on pad , numlock off. NO drives told tell me it is sata boot, drives not relic junk IDE (pata) in bios disable raid and save BIOS main <DEL'> hot key. the coin cell is dead why skip act 1 ? 7 years old is max life. EOL so replace that first reset bios inside bios see time and date set raid CHIP OFF, in bios set boot order of HDD 0 boot is there and good HDD safe exit cold boot it. install w7 is max ,w8 up lacks key drivers for the mobo seen below. link to makers site if your read the manual and see page on control+F RAID rom there all you need is there, in that free manual. page 72 B2 quote "Important Be sure to enable the RAID functon for SATA devcen BIOS before configuring the RAID Opton ROM Utlty." the means same in reverse too, to disable radio do so on main bios there are to bios here,main and raid. page 48 https://us.msi.com/Motherboard/870AG46/support#manual books there and all w7 drivers too. main raid mode, (off)
5/23/2022 4:06:02 PM • MSI Computers &... • Answered on May 23, 2022
The dvd drive on my msi cr610 laptop will not
load VLC program free from France not told burned with what, not told files there does explorer see the files, first. mp4 file or real DVD formatted structures with Video_TS folder and vob inside? nobody can guess what you burned there and there are like 100 video formats to put there, not one can I guess.
5/23/2022 3:01:36 PM • MSI Computers &... • Answered on May 23, 2022
MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard (7592-030R) Logo
Popular Tags
14 questions posted
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • MSI Computers & Internet
Most Popular Question
no dvi signal g41tm e43
  • Computers & Internet
