Check the fuses first, swap relays. If that doesn't work. Takes a scanner to see what is not working. If the PCM is getting the signal, then look to the wiring to the fuse panel, to the relays. Cold be the relay/fuse panel.
? 4:31
https://www.youtube.com/watch?v=sz_oe9tIFH4
Jul 3, 2011 - Uploaded by Jaime Depaula
Land Rover Freelander 2002-2005 KV6 Timming belt andreplacing valves - Video 2 ... shops in North Eastern USA for bent valves and timing belt change? .... Land Rover 200tdiTiming Belt -From Broken Belt to Retiming the ...
? 10:52
https://www.youtube.com/watch?v=1Qn8ljQKZxA
May 4, 2012 - Uploaded by metalworker007
How to change a rover K series cam belt .. by Technozen of ...soy espa?ol porfavor quiero saber timing marks de MG ROVER 25 petrol 1795cc engen .... Hi, Have a Land Rover Freelander1999 petrol serie K, that dont start, ...
Nov 20, 2006 - 1 post - 1 author
The following is instructions for replacing the timing (or camshaft) belt on the 1.8i petrol engine, as fitted to a Freelander. This is the K-series ... With the timing set, thecam sprocket marks should look like this. Posted Image
is the engine getting up to a good operating temperature , may have a problem with the thermostat not opening or even the water pump not working , if engine not hot enough fan won't cut in
can anyone let me know where i can get details on problems known by land rover on the head gaskets having a problem on the freelander 1.8 petrol 2004 models
