I need a part for my WHIRLPOOL Stove model WCP58580 that is so old it does not come up on whirlpool's parts online website and I dont know where to go and find one. I need the switch for the top burner (the one located on the bottom left side (larger eye)).
Look at www.repairclinic.com
They are a very good resource for appiance parts.
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
SOURCE: stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
SOURCE: My whirlpool Self-cleaning oven model
Hi, Your problem is very frequent and also very easy to be fixed. You need to replace the thermocouple. Is the metallic rod near the burner that the by heat is holding the gas valve open.It is similar to troubleshooting as mentioned bellow: http://www.ehow.com/how_7198168_do-troubleshoot-whirlpool-rm286pxv_.html Please get back to us if you have any further query or else accept the solution. Thanks for contacting fixya.com
SOURCE: Have a whirlpool elec range giving a power failure
Here is a tips that I wrote
that will help to explain why you get the PF Error Code
PF
Error Code for Appliances
heatman101
