I forgot my password. this machine has Vista on it.
Download hirons bootcd off google then burn it to a disc with free iso burner and follow instructions on youtube how to change password How To Reset Forgotten Password Windows Xp Vista 7 Hirens Boot
SOURCE: During loading of window drivers the machine shut off.
go into systen bios and set the default leave it there for a good duration doing notheing. see if the machine dies if not save the setting and reinstall using the Boot from CD.
DO not Boot from HD
try a different CD drive unit too.
SOURCE: forgot password
some computers have safe mode accounts that run as admin that don't have a password try going into safe mode here are the steps to get into safe mode
one turn your computer completely off
two turn your computer on and immediately hit F8 repeatedly till a menu shows the using the keyboard select safe mode
you should see a ***** of text go by don't worry this is normaly now the computer should go to the account's page select the administrator account and the computer should log you in fromhere goto the control panel and accounts page and ethere try to change the password on the old account or make a new admin account hope this helps
SOURCE: HP Mini 110-1125NR/100-1125NR PC forgot admin
no password, no dice, safemode maybe but yeah might have to format be more carefull
SOURCE: I forgot my e-recovery password, no recovery disks...
Don't you have created the password Recovery disk early?
If you do, you can sign into safe mode and recover the password.
If you don't have the password reset disk. you have to take use of the 3rd party utility,
Windows Password Recovery 6.0 is highly recommend. It is fast and easy to use.
SOURCE: I have this hp a1700n
It may be easier to ask a local tech to burn you an OEM copy of Vista Home Premium(or basic, whichever you have) and do a custom install. they normally will do this for free or for a couple dollars as long as you have the license on the side of the case. It's more time consuming and in depth but it has a higher likelihood of working.
It is not so troublesome that you forgot Windows password, you can see this article about Windows 7/Vista/XP/2008/2003/2000 password recovery. Two steps:
1. Create a password reset disk;
2. Reset Windows 7/Vista/XP/2008/2003/2000 administator password offline!
It is not so troublesome that you forgot Windows password, you can see this article about Windows 7/Vista/XP/2000 password recovery. Two steps:
2. Reset Windows server 2008/2003/2000 local or domain password offline!
