Polaroid CZA10011B PoGo Instant Thermal Printer Logo
E
Ernesto Ramirez Posted on Apr 21, 2014
Bought a new rechargable battery and cord but it won't charge.
I bought a new battery and cord for my Polaroid Pogo instant camera, but the battery won't charge. If I plug it in directly to the outlet, it functions normally. But when I pull the plug, the camera shows "low battery" and dies. How can I fix this?
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Oct 30, 2009
SOURCE: bought today..does battery have to be charged for 3 hours before use? please advise
first of all make sure that the pogo it turned off insert the paper from the packet with the blue peice on the bottom with the barcode facing down. and the paper facing shiny side up and logo face down. when you turn the pogo on the blue paper will feed through first then the printer is all setup and aligned ready to print via bluetooth or via USB cable. hope this helps
Anonymous
  • 14 Answers
SOURCE: my polaroid pogo wont print
when printing make sure that the paper is inserted in the pogo shiny side up and logo facing down. also try putting through the blue alignment sheet first as the pogo will not work without this. hope this helps
Anonymous
  • Posted on Dec 26, 2009
SOURCE: i recently bought a polaroid pogo instant mobile
keep getting an "Unable to send to:"readinging.
Anonymous
  • Posted on Apr 09, 2010
SOURCE: got polaroid pogo printer will connect with
have you put the paper in with the barcode card piece at the bottom and did this piece automatically come out when you closed the lid?
Anonymous
  • Posted on Jan 01, 2011
SOURCE: wont print from digital camera
Look in your camera settings and change the connection from USB to Pictbridge. If that's possible then you should be able to connect.
Does it take batteries
The Spectra AF camera film packs contain the 6V battery that runs the camera. The manual for the Spectra camera is available here: store.polaroid.com/media/document/spectra_af_ug.pdf . See page 21 (page 29 of the PDF). Unfortunately, considering how long these cameras have been available, the film packs may be hard to find.
I hope this helps.
(even new cameras with rechargeable batteries sometimes need a replacement battery pack. The battery can't recharge forever.)
1helpful
Hi, I have lost my charger to my Polaroid two pogo camera where can I please get a replacement?? Thank you Jon green
Hi, I know this is quite late but I have been searching for one for ages and I finally found one! http://www.powerpayless.com/9v-ac-adapter-for-polaroid-cza-05300b-pogo-instant-digital-camera.html I hope this helps anyone who is trying to find a charger for their Polaroid Two. :)
4helpful
I have the polaroid pogo. how do i open battery door?
Assuming it is the PoGo instant mobile printer ... (and not a digital camera - category that you posted your question) ... slide the battery door cover downwards to open.
See the illustration in the 5th page of the manual (under installing and charging the battery): http://office.manualsonline.com/manuals/mfg/polaroid/cza10011.html
I was given a polaroid pogo as a present at Christmas but the battery will not hold it's charge I fully charge it but when I turn it on the next day the red light shows no power how do I go on about a...
try to change battery with similar one, then recharge it. usually before recharging battery level should be on low-bat condition. by doing that you can prolong the life of rechargeable battery. be sure follow manufacturer recommend type of batteries-i.e. alkali, lithium-ion
My Polaroid i1237 Camera Has A Low Battery. They Require Alkine Batters [Double A). I Have The USB Cord, Wris Strap, and an Extra Memory Card. The Battery Is Lowwww, So Do I charge MY Camera With The USB...
Alkaline batteries are not rechargeable...in fact, it would be dangerous to try to charge them. You can purchase rechargeable NiMH AA batteries that come with their own charger. This will save you a lot of money in the future.
1helpful
4helpful
2answers
Needa charger cord for polaroid m737t
You cannot charge this camera through a USB cable, you need to use the battery charger that comes with it. If they didn't give you a separate charger, you need to call Polaroid and order a new one, but be prepared to pay almost $30.
5helpful
Battery
The battery pack is built into the film cartridge. Every time you insert a new film pack, you get a fresh battery. Problem is, you are going to have a hard time finding Polaroid film, as they have ceased production of most of their instant film packs.
Top Polaroid Office Equipment & Supplies Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
