Motorola Mobility HS850 Consumer Headset Logo
A
Anonymous Posted on Apr 14, 2014
What is the password for Moto HS850
  • Official Brand Answer 1,623 Answers
  • Posted on Feb 10, 2015
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350754
Points
5677
0000
Mark
Motorola Support
1helpful
2answers
I have this motorola n136 that I used with my old Samsung phone. Then I bought a new samsung and bought a new charger for the blue tooth and now I cannot synch the two together.
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:>>>>>>>>>
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
4helpful
Hi, I have an bluetooth n136 hs850 and it is turned on and blinks ,but i cant get it in descoverble mode, it wont stay blue keeps blinking, can youtell me how to get it in discoverable mode? thankyou
close flap (off mode) hold down the "on" function button until the blue light comes on. once it comes on open the flap.. the blue light should stay on. you should already have your phone set for pairing. if your phone ask for a password. its generally 0000..but heres a link to the guide..http://direct.motorola.com/hellomoto/motosupport/source/generalpairinginstructions.asp?p_headset=742
What is the password to connect to my blackberry
more than likely its 0000 until you change it but it should be in the instructions with it.
Hs850 password forgotten.
From what I keep seeing, the password can never be changed into a personal. It's always going to be either 0000 or 000000.
HOW DO I PAIR MY HEADSET
click the smart bottom for 3 seconds will turn off the device, and click for 8 seconds when the led start blinking then it is ready for pairing , then search for the device on the phone and the password is 0000.
Motorola HS850-
almost all of moto bluetooth headset get this problem. i think H680 is much better that HS850 or H700. i'm using RAZR2 V8 and almost all BT headset have static problem. So i end up with korean's and french's BT headset which have much lower static.
Moto bluetooth HS850 WON't turn ON!
I think your guess is right a new battery may be required but try leaving it on charge for 12hrs or so sometimes if they havn't been used for a long time they go dormant and it takes a realy good charge to get them going
Answering Calls with Motorola HS850 on Sony Erricson T630
i think rapid connect should work with moto phone only, isn't it?
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
