Kodak EasyShare One Digital Camera Logo
Posted on Nov 01, 2007
Kodak easyshare camera not transfering photos
My kodak easyshare camera will not transfer my photos to the computer. Everything is plugged in and the camera is blinking but nothing is happening. Please help. I checked the connections, they are fine.
Carole
  • 26 more comments
  • sooke Nov 05, 2007
    Camera is not recognized by the computer. USB port is enabled and working (I can download from my Fujifilm camera through the same USB port). I have uninstalled and installed the driver many times. I have followed Kodak's 6 page procedure for checking USB port configuration, conflict identification, etc. . I get the following message on the USB conflict- "Windows can't load the device driver because a previous instance of the device driver is still in memory - code 38".
    Gary
  • tocfarm Dec 12, 2007
    This solution would have been helpful if I had recieved it sooner. I sent this in on Nov. 1st and it is now Dec. 11th, thus I have already found the solution. You were correct but hardly any help since it took so long for you to respond.
    Carole
  • shuz Dec 17, 2007
    my kodak Z612 woked one day then the next it didn't! it plugged in via usb, no other device is plugged into usb. it works on my dads pc using the same usb cable, but not mine. the computer says ' no device connected' when it is. ive uninstalled and reinstalled software, nothing has worked, HELP.
  • Anonymous Dec 21, 2007
    need simple instructions to transfer pictures from c713 to my pc
  • tech212008 Jan 21, 2008
    I was able to connect my KODAK M753 camera to my computer, turn it on and have my computer recognize the camera as a drive. Which allowed me to copy, cut and or paste my pictures off or on my memory card. since formatting my computer. I attach my camera to the same computer, and now, it sees it as a camera/scanner, and now only allows me to copy and paste pictures from the card. i loaded the software for the drivers, but it did not help. my computer doesn't recognize the device. how do i get it back to the way it was, is there a driver that i can install that will allow me to copy and cut and paste, as if it was a drive?
  • SEBASTIAAN Feb 04, 2008
    C530 camera I cannot trasfer pictures anymore although I follow the right procedure which worked before. Selection seems to be OK; the camera light is blinking but a few seconds after the transfer the event log appears that no picture has been copied to the PC. What should I do?
  • Anonymous Mar 01, 2008
    I don't know how to download pictures from m753 kodak camer to my computer
  • abby K Mar 04, 2008
    when i plug it in and try to get my picture it said cannot get device information
  • Sunbunny May 14, 2008
    I have my Sony cyber-shot connected to my computer and the easy share comes up but says there are no pictures to transfer but I know and the camera tells me the memory card is full.
  • Anonymous May 28, 2008
    i have a kodak easy share digital dx7440 hooked up to my computer , i turned on the camera and the monitor screen said digital camera transferring.
    but...nothing happens!!!!!!!
    this is the same procedure that worked before, why not now ?
    [email protected]
  • kesia May 29, 2008
    my camera is hooked up to everything just find, and its starts to upload then stops and tell me theres an error with the camera plug.
  • trickchris Jul 02, 2008
    i am trying to transfer pictures from my camera to my computer using the computer cable. does not work for me. is there a certain setting i should have the camera on whenever i plug it into the computer?
  • gindosg Jul 10, 2008
    Ahmed
  • Anonymous Jul 23, 2008
    My Kodak C360 will not transfer pics even though I have successfully load the software. It says the device is not connected.
  • mookie_babie Aug 08, 2008
    cannot transfer pictures onto my PC
  • goonagain Aug 20, 2008
    'cannot set the device information' shown when trying to transfer from camera CV7525. have previously transferred successfully
  • bl61 Aug 25, 2008
    I try to restore by reinstalling with the kodak disk and restore everything i could possibly do . I can not get the computer to recognize the camera and pictures like it just did less than a month ago. please help
  • brooklee Sep 19, 2008
    help! i cant download my pictures onto my computer and i have a kodak chip.
  • Lpeters Sep 22, 2008
    I have the same problem, but removing the software did not help- my Kodak EasyShare does not appear to be communicating with my Mac. Nothing is showing up on my desk top, and the camera just blinks...
  • Beau Graham1 Oct 25, 2008
    My camera chip is into my computer, but it dont read the chip. I dont know what the problem is but i need it fixed
  • Anonymous Dec 10, 2008
    i have the same problem :(...its so frusterating
  • robcrew Dec 26, 2008
    easy share does not import photos onto mac computer
  • Anonymous Dec 30, 2008
    I cant trasfer pics from my kodak to my computer
  • Anonymous Mar 04, 2009
  • Anonymous Oct 20, 2012
    Thanks so much for advice about disconnecting other devices. Once I unplugged my scanner, voila, the Kodak camera then was recognised.
  • Anonymous Mar 16, 2014
    software to upload photos from Kodak EasyShare camera
  • Anonymous Mar 21, 2014
    Kodak Easyshare program is not on my windows 7 pc
  • Anonymous Mar 23, 2014
    Plugged camera into computer as usual, but nothing happens
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 17, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7925
Points
6
Anonymous
Level 1:
  • Posted on Dec 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7925
Points
Every time when I try to transfer new photos from Kodak Easy Share to my computer,some of the photos will not get transfer at all. What do I need to do? Please help! I hope I will not have to wait for responds for too long. Thank you!
Anonymous
Level 1:
  • Posted on Nov 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
7925
Points
I cannot transfer pictures to my computer. Please help
Anonymous
Level 1:
  • Posted on Nov 29, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
7925
Points
I have a kodak camera model m753 just bought a new computer with visa can not transfer pictures into pisa program any help would be appreciate.
A
Anonymous
Well the solution helped me so i'm glad it was posted thanks
A
Anonymous
Had the same problem with my kodak m753. I deleted the kodak software by going to start>setting>control panel>Add/Remove>Kodak Easyshare software. When complete go to www.kodak.com/go/clear. and follow the instructions. When you restart your program do-not reload this Kodak software ( there seems to be a problem with it that they have not fixed). If your camera worked before then it will work in the usb port this time. If you need a program for sorting and keeping track of your pic's I suggest Picasa2 or Adobe file share ( do a google to find them) Both are free and excellent They will recognize your camera and you will be able get the pic's you what from your camera.
A
Anonymous
This happens when you have another device on the USB (such as a multi-function printer, scanner, etc) that loads the USBSCAN.SYS file. It is not a mutex driver so it can't load at the same time.
6helpful
Kodak z710 I cannot transfer photos onto my computer.
It may be time to buy a card reader for your computer. You can get one at a department or electronics store for not much more than a cup of coffee.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
2answers
Z990 with USB from computer to camera will not transfer pictures to Kodak easyshare
there is at least 3 way to transfer pictures from camera. this video explains all three.
How do I delete photos from my internal memory
KODAK EASYSHARE Software is only compatible with KODAK EASYSHARE C-, CD-, CW-, CX-, DX-, LS-, M-, P-, V-, and Z-Series Digital Cameras; and DC4800 Digital Cameras. If you have one of these camera models, go to Step-by-Step Solutions and Repair tool to help resolve this problem.
If you have one of the other digital cameras, you cannot use KODAK EASYSHARE Software to transfer pictures to your computer. Use the software that came with your digital camera to transfer the pictures to the computer. When your pictures are on the computer, you can use EASYSHARE Software to edit, share, and print your pictures.
Problem downloading photos from camera to computor
KODAK EASYSHARE Software is only compatible with KODAK EASYSHARE C-, CD-, CW-, CX-, DX-, LS-, M-, P-, V-, and Z-Series Digital Cameras; and DC4800 Digital Cameras. If you have one of these camera models, go to the Step-by-Step Solutions and Repair tool to help resolve this problem.
If you have one of the other digital cameras, you cannot use KODAK EASYSHARE Software to transfer pictures to your computer. Use the software that came with your digital camera to transfer the pictures to the computer. When your pictures are on the computer, you can use EASYSHARE Software to edit, share, and print your pictures. Hope it helps you.
Kodak DX7630 camera - using Kodak easy share - photos won't transfer - message says they are already transfer
All digital camera put number on there files. Go to your windows search and search for your file that you transfer. The search will tell where it is located on your computer.
How do I get my pictures off my internal memory of my camera?
To transfer pics to your computer you will need to install the Kodak EasyShare software (you can download it at www.Kodak.com) and connect the camera to the computer via USB cable or a camera dock. To delete the photos press the Review button and then the Delete button. The camera will give you the option of deleting everything or a single pic.
What exactly is a kodak camera dock? I have a M893 IS kodak camera and having difficulty installing the software so I can transfer my photos to computer - so I thought maybe the "kodak camera jack" would...
The Kodak camera dock provides automatic battery charging and automatic connection to your computer when the camera is "docked." There is also a version of the dock that includes a printer, but I have found the printer to be poor quality and very unreliable. The dock must be connected to the computer via USB, and the Kodak EasyShare software must still be installed. The dock is a very handy accessory, but it will not solve your problem. What might help though is a visit to Kodak.com where you can get a free download of the latest EasyShare software that is correct for your operating system.
I cant transfer my photos to my pc from Kodak EasyShare CX7430
Remove any Kodak Software. Reboot the computer Plug in the camera. This should now be listed as an extra drive in 'My Computer' and/or The scanner/Camera Wizard Window will come up asking what action to take.
Download movie by Kodak Easyshare
Instead of using the software... Try uninstalling the software and use the Microsoft Scanner and Camera wizard to transfer photos/video to your computer. It should recognize everything on your camera, and then you can copy and paste the photos/videos into whatever folder you specify. In my experience, Kodak's EasyShare software was able to recognize .MOV movies. If your computer is slow, you might want to wait a while for all the processing to be done and check if the videos were recognizeD
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
