What are the pin connections needed on the output connector to operate this power supply on the bench
SOURCE: DELL POWER SUPPLY TYPE PS-5201-5D REV.F
230 Watts.
Here are specs and replacement:
230W ATX Power Supply - PS-5201-5D - HP-233SNF ...You can also replace it with a compatible 300 W psu.
SOURCE: FAULTY POWER SUPPLY FOR LITE ON PS -5251-2DS
when connected the AC power , no DC voltage reading from the p.s.
what to do?
how can i turn it on?
SOURCE: PS works only when i short wire green & black on 20 pin ATX .
Sounds like it's not grounding properly. Safest thing to do would be to replace the power supply. Hope this helps.
SOURCE: Power Supply Replacement
It never hurts to have a larger power supply, yes it have use 100watts more in a hour. But you should have better reliability with the 450W.
Mark
SOURCE: Can you supply pinout for Dell AA23300 Power Supply ?
On the main plug there is a single green wire. Jumper the green wire to any black groung wire in the plug and the fan will start and you will have output.
