SOURCE: belt wont start on a brand new Sole F80. Motor
It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
SOURCE: My Sole F80 deck bounces excessivly when not at an incline.
1) Lube the deck belt, this problem is lack of maintenance, maybe the deck belt is worn.
2) You must align the deck belt see the diagram
3) Lube the rollers bearing very well very important too
see the video: God bless you
SOURCE: SOLE F80 treadmill makes a audible
Dear Sir:
Sound like metal touching metal, could be roller bearing or bearing main motor.
You have 2 options: 1) Do it yourself or 2) Call to service Tech.
God bless you
Testimonial: "Thank you so much! I have a service tech coming out next week to take a look at it."
SOURCE: my fans dont come on, on my brand new sole f80 treadmill
1( test the voltage to the terminal , if there are voltage the FAN is faulty, change it.
2( if there are NOT voltage to the terminal FAN, test the line why are NOT coming voltage, test some fuse, or c. breaker, tight any plug, connector, or loose wires.
3( Try again.
see the block di attached. and fix it.
God bless you
