Not getting cold, is there reset button?
If it is not getting cold I would first check the t-stat to see if it is operational only after seeing if there is power to the t-stat. If it is good then you most likely have a compressor problem. Check the overload on the compressor under the black cover on the side of the compressor if power is getting through that and still not running then comp is shot.
good luck
