SOURCE: trying to pair motorola n136 with my sprint rumors phone
Found this when trying to pair mine:
I had the same problem - what I thought was the unit number was not - it is actually HS850. Instruction manual is here:
http://www.motorola.com/mdirect/manuals/...
Basically, hold down the call button until it lights up (steady -not blinking), open the boom, and search for devices in your phone. When it finds it, the passkey is 0000.
SOURCE: How to pair up headset with cell phone?
first ul hav to press the button(big one) for a lil while..let the snap b closed...the light wud change to purple...then at the same time set ur bluetooth on the samsumg mobile to discoverable mode....snap open ur bluetooth and in ur mobile it will ask for a pass key which in default is 0000...then it will get connected
Thanks for using Fixya
keep me updated for further assistance
SOURCE: Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
SOURCE: Cant Pair my Motorola H500 to my LG Rumor
turn bluetooth on your phone on. then on your bluetooth headset hold the power button for about 10 seconds or until you see the bluelight on steady. next on your phone in the bluetooth section klick ok on the search for device option, when you found the bluetooth with your phone it will ask if you want to use that device, klick yes, and it might ask you for a code, enter four zeros "0000" and that should connect automatic.
