I have a Gold Star and want a new Black and Decker. Is one better than the other because my other machine is over fifteen years now and doesn't knead properly. A black and decker.
SOURCE: Black and Decker B2300 Bread maker problem
Im having the same problem, anyone find the solution?
SOURCE: Black and Decker Bread Maker B2250
Here's a good basic white bread recipe that works great with a BD2550 (and usually doesn't even **** the mixing blade into the bottom of the machine
1 cup warm (not hot) water
1/3 cup milk
1 tablespoon sugar
1 teaspoon salt
1 1/4 tablespoons butter/margarine
4 cups flour
1 teaspoon yeast
Heat the water and add the milk to it. Dissolve the sugar and salt into this mix and pour the liquid into the bottom of the bread maker bucket (make sure the mixing blade is already in). Melt and add the butter to this mix. Add the 4 cups of flour directly on top, but do not mix it in. The flour will float on top of the liquid. Make a small dimple in the top of the flour in the middle with your finger and add the yeast into that little crater (at no point while adding ingredients do you let the yeast touch the liquid). Set the bread maker for basic setting 1, light crust, 2lb loaf and let it do it's thing. 3 hours later, you'll have a nice loaf of white bread with good consistency and density, and it usually leaves the mixing blade in the bucket (rather than having to dig it out of the loaf after).
Hope this helps!
SOURCE: black and decker bmh200 maunal
I have a copy of this Black and decker bread maker manual. Any information you require from this, I am happy to help with.
SOURCE: I have a Black & Decker B2200 bread maker on
I just bought a new b2250 machine from Zellers for $59 dollars, they also have the b2000 for the same price. It's not worth your time to mess around trying to fix these things.
SOURCE: Our rarely-used Black and Decker B1650 bread maker
It could be the belt is slipping or a loose gear. Take a look at the gear & belt assembly in the base of the machine. Also, make sure the sealed bearing in the bottom of the bread pan is not sticking. It should turn free by hand Hank
Testimonial: "thank you for the great suggestion"
