Hi Jorge
Internally a standard 3.5" Hard Drive uses two voltages
about .7A on the 5v Line
and .55A on the 12v line.
So an External AC Plug Pack supplying 12v @ 1.5 to 2Amp should be adequate.
Be careful to match the polarity as marked on the back of your drive and use the correct thickness of the centre pin. There are 2-3 different sizes of this connector available at electronics component suppliers in case you make your own supply up.
Good Luck
Trevor
From the information provided, it appears to be a direct hardware failure. Verbatim appears to not offer much on providing information on such issues, so it would be safe to say is have it replaced.. I am not 100% sure but some external drives come with a 7 year warranty, you could also try to have your data recovered from a local computer service in your area so you do not lose the data. But, in all it would be advised to replace it.
That beeping signals a failure to communicate between the disk and the motherboard of the pc - the disk is defective. You have a slim chance of recovering what's on it by removing the actual disk from the external case and plugging it in the a desktop.
Usually there is a pattern to the beeps, but more than likely it is a problem with the ram you just installed. Where did you get it from? I checked with crucial.com and that is the right type of ram, but you may have a bad stick.
