Doubt you can get them that is a legacy Konica Machine early 90's at best mite be XP.
but try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: reinstall drivers for konica bizhub 7222
I work with Konica
If you need Help Email me and we will work out the details latter for as Phone assistance
Thanks
email me at
[email protected]
SOURCE: konica 7222 f28-3 code
part # for the t/s unit is 40la-2600. if you need it I can order the part for you
SOURCE: How do you change the time on the bizhub 7222?
Enter in the user tools and setting the value.If don`t work tell me for more information.
SOURCE: will the fk-102 fax kit work on konica 7222?
the 102 will work but not all the features will work like with thefk103
SOURCE: konica minolta 7222 model f-35-4
Related with the heater. check two thermistors and other parts if the avery thing is ok then:
Reset code using 25 mode, dipswitch 3, bit 1 is the fuser reset command "0" is no and "1"for yes
presumably this means that if you must reset a fuser fault, you enter this mode, select dipswitch 3,select bit 1 and change no to yes , by pressing "ON"
