is car a/t trans or stick Ill post as automatic trans....
all answers USA RHD car. not export.
so got the schematic yet.?
or want to work blind.?
id find he cause of spark first.
implies phyisical damage.,
best is to correct obvious real damage first.
then we diagnose. I cant see your damage so im blind.
chapter 8w is fire on the WJ
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
1: check fuses first.
2: check battery voltage next. 12.6vdc rested, no less.
if less charge the battery with a charger.
3: scan it is next. all use cars scan 1996 + with any scan tool.
you willl see, errors, called DTC , post them.
no crank. in park.
does it crank in NEUTRAL>>>>>??? per oper guide?????
if that fails, and hot wiring the starter it cranks?
then we attack the key switch.
the start line on the switch must go to 12vdc cranking
10 to 12vdc if start actual works (this loads down the volts on average to 11v)'
this wire is Yellow. doe this work.
if yes,
make sure the starter relay closes,
the relay only closes in park and neutral.
does it? cranking/
