I don't know of illustrated instructions but I can provide you with the service manual for your TV. It does have illustrations of disassembly and components as well as schematics. Your set very likely needs new convergence IC chips. This is a common problem with all projection TVs. The repair is not expensive ($60-75 in parts) but does involve unsoldering and removing the old chips and soldering in new ones. Some times there are some fuses that need to be replaced as well. If you want the manual provide me with an email address.
You don't.
It should automatically switch to 1080 when and only when there is a HD signal present. Otherwise it will be in 480 and you will need to use the format button on the remote to change the picture size. If it does not switch to 1080 and you know for sure you have a true HD signal present, there is a problem with the unit.
Hope this helps,
Skyassoc
need to know what remote you have to help do you have a model # or if you go to this site you will hind the 2 remotes S I sells. Click on the pic. then you can download the manual. Hope this helps. If the remote is not there Get me the model # and I will find the codes for you.
This is a convergence rpoblem that is either bad connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside TVs where there are potentially dangerous high voltages, let me know and I'll provide additional details and instructions for fixing this yourself.
1080 is a High Definition setting. If your Television is HD capabilities you need to make sure that the programming that you are viewing is being broadcasted in 1080. If it is not then you will see a difference in picture quality and sound. If no color at all and program being watch is HD programming check your connections on back of Television. depending on what kind of input the Television is receiving you might need to try new cables or a new input. Good luck
check and re-solder the connections on the 2 convergence ICs in the middle power board. they are going to be attaches to the biggest heat-sink in the tv. if the re-solderingdoesn't fix then replace with STK392-570 i would replace both but if you look at the board you should be able to figure out which chip is responsible for the vertical and which is the horizontal convergence. each IC converges all 3 colors but one is responsible for one axis.
