Sparkle Power SPI FSP300-ATX GT 300 Watt PS (fsp300-60btv) Power Supply Logo
A
Anonymous Posted on Mar 17, 2014
Sparkle power atx -400pn wiring diagram - Sparkle Power SPI FSP300-ATX GT 300 Watt PS (fsp300-60btv) Power Supply
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
3answers
How to make a pc power unit work without a motherboard?
There are two pins on the atx connector you need to bridge. You can wire a switch to the pins too if you want so you can toggle on and off. Otherwise, there is a guy on eBay (seller id: antronst) that sells a connector with the pins already bridged with a on/off switch and a resistor wired in to provide some stability for five or six dollars.
Here is a diagram. Make sure it is a standard atx power supply. Some old Dells had goofy wiring.
http://www.techpowerup.com/articles/other/22
What is the value of R61 resistor
It's not worth enough to warrant you risking your life to replace it. Especially on that piece of garbage PSU. You can die if you try fixing a power supply and touch the wrong thing inside. Seriously.
1helpful
I canoot play my games
then do your work instead of playing game.
Solution No.1: Turn your computer on to play games.
Solution No.2: Install your games to play them.
you should better describe your problem why, when or which error message comes when you try to play them.
Top Sparkle Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Sparkle Computer and Internet Expert? Answer questions, earn points and help others
