SOURCE: EasyCAP USB 2.0, can't install driver from CD, Window Vista
Your going to need to download the drivers for it off the internet. The same problem happened to me so i decided just to search for the drivers. I downloaded them, and then when i was installing it asked "Search computer for drivers" so i did that and found where i had downloaded the drivers to and then the EasyCap Capture Card worked. The only problem is you will need a good recording program to record with because the program they give you probably will not work. I decided to download AmCap which is a software that lets you record with your Easycap. Also i downloaded Pinnacle Studios 12 to record. If you have a Windows xp computer you can use Windows Movie Maker to record.
