Not sure what you mean by new and old grand total. There is normally one grand total and that should print by default. It is affected by everything you do. It can't usually be edited or reset as it is there to stop fraud. Most people do not use it. You only need the daily totals that get reset after a Z report
Testimonial: "on my old register it said new grand total and old grand total. when I put it into an excel sheet it would break down the math for me."
SOURCE: SHARP ER-A440
2. Master reset (All memory clear)
There are two possible methods to perform a master reset.
· MRS-1
Used to clear all memory contents and return machine back to its
initial settings and return keyboard back to default keyboard layout.
Procedure
1) Unplug the AC cord from the wall outlet.
2) Set the MODE switch to the (SRV¢) position.
3) Plug in the AC cord to the wall outlet.
4) While holding down JOURNAL FEED key, turn to (SRV) position
from (SRV¢) position.
· MRS-2
Used to clear all memory and keyboard contents.
This reset returns all programming back to defaults. The keyboard
must be entered by hand.
This reset is used if an application needs different keyboard layout
other than that supplied by a normal MRS-1.
Procedure
4) While holding down JOURNAL FEED key and RECEIPT FEED
key, turn to (SRV) position from (SRV¢) position.
5) Key position assignment:
After the execution of MRS-2, only the RECEIPT FEED and
JOURNAL FEED keys can remain effective on key assignment.
Any key can be assigned on any key position on the main keyboard
i found this on the manual at this site...
http://www.skan.com/Manuals/A440/ERA440-SRV.pdf
SOURCE: casio cash register pcr-t470
Electronic Cash Registers, Tax Table Programming
9:00am to 8:00pm
Monday - Friday
9:00am to 8:00pm
Saturday/Sunday
Live Technical Support
800-638-9228
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Need free programming manual for Casio TE-2000 cash register
Hi. I don't have any downloads, but I know this model, so I can help with programming.
Mark
SOURCE: My Cash Register Sharp ER-2386 show me just a 0
YOur register lost the program or it has no battery power and was left unpluged. If you do a master reset it will all come back. At the moment it is most likely the program is corrupted and needs a master reset. It is done by turning the key (if you have a service key) to the blind position and holing down the journal key and plugging the machine back in, oh yeah you are suppose to pull the plug first. then program in the time and date and what ever else you may wat
Chris
