Zebra ZXP Series 8 Thermal Card Printer Logo
A
Anonymous Posted on Mar 11, 2014
Error code 7010 - Zebra ZXP Series 8 Thermal Card Printer
How do you connect 3 monitors on an Optiplex 7010,Dell 7010 has 2 DP ports built in and 1 Vga port
To connect three monitors to a Dell Optiplex 7010, you can use the built-in DisplayPort (DP) ports and the VGA port. Here's how you can set it up:
  1. Check the available video ports: As you mentioned, the Dell Optiplex 7010 has two DisplayPort (DP) ports and one VGA port. Make sure all three monitors support at least one of these connection types.
  2. Connect the first monitor: Use a DisplayPort cable to connect the first monitor to one of the DP ports on the Optiplex 7010. Ensure that both ends of the cable are securely plugged in.
  3. Connect the second monitor: Connect the second monitor to the other DisplayPort (DP) port on the Optiplex 7010, using another DisplayPort cable.
  4. Connect the third monitor: Since the Optiplex 7010 has only two DP ports, you'll need to use the VGA port for the third monitor. Connect the third monitor to the VGA port using a VGA cable.
  5. Configure display settings: Once all three monitors are connected, you'll need to configure the display settings to extend the desktop across all monitors. Right-click on the desktop and select "Display settings" (Windows) or "System Preferences" -> "Displays" (macOS). From there, you should be able to set the arrangement and orientation of the displays.
Note: When using multiple monitors, it's important to consider the graphics capabilities of your computer. The Optiplex 7010 might have limitations on the maximum resolution and refresh rate it can support across multiple displays. Check the specifications of your specific Optiplex 7010 model to ensure it can handle three monitors simultaneously.
If you encounter any issues or limitations, you may need to consider using additional hardware, such as a DisplayPort splitter or an external graphics card, to connect and support three monitors.
Epson 7010 all lights flashing & won't print
Epson printer blinking different lights. The different lights blinking has different meaning and solutions. When the Epson printer red light blinking that means ink cartridge of your printer is out of ink. And when your printer green light blinking that means paper gets jammed inside the printer.
You can fix the Epson printer lights blinking error using following steps:
·Fix the paper jammed
·Check empty or damaged ink cartridge
·Clean the dirty print head or replace missing or failed print head
·Read the steps to fix the Epson printer lights blinking error.
Brother dcp 7010 errors unable to print Use user guide but problem not solved
Hi Raj, please describe the error details( paper jam, color lights, blinking, solid, toner is original /refilled ? Recently changed-opened the fuser or the drum ?
To reset the drum error for a Brother DCP 7010 printer:
Turn the printer on and leave it like that.
Open the front panel.
You should see on the screen a message : drum change. Press "yes".
After that, the LED that was flashing near the drum will stop alerting.
2helpful
How can i reset printer
Hi Ajit,
Please visit this site in order for you to reset your printer. Hope it helps.
Brother DCP 7010 Drum Unit Reset Instructions
1helpful
Safeboot hard disk error (80H)
You need format your hard disk... sorry but if your problem continues... is logical error or hardware error.
No view of Olympus 7010 screen after dropping
You'll have to take the camera in for service to replace the component that was damaged in the fall.
Unfortunately, the cost to repair the camera will most likely be as much or more than just buying a new, replacement camera.
1helpful
DCP 7010 How to install without CD
you didnt mention what your operating system is but go here this should help..... http://www.soft32.com/download_181357.html
2answers
Dcp 7010 scanner locked error on lcd display
Error: Scanner Locked Cause: The scanner glass’s sensor does not move to the home position. Action: 1. turn off, and then on 2. if (1) doesn't work, chek sensor
Top Zebra Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
ExpressFiX
ExpressFiX
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
