Whirlpool LGR4634J Gas Dryer Logo
Posted on Jun 12, 2009
Whirlpool gas dryer #lgr 4634 jq0 not drying and rattling noise
Gas dryer not drying and making a rattling noise
  • Anonymous Mar 13, 2014
    there is a noise whenmy whirlpool gas dryer runs, sounds like a roller is bad
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jun 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
2177
Points
25
Is the dryer tumbling
My LEV 4634 PQ0 dries the clothes fine but make a very loud rattling noise-anyway to quiet this machine?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
I have a Whirlpool Imperial Gas Dryer (Model:LGN2000.JQ0) where the heat will intermittantly go on or stay off. Can you let me know what would cause that?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Whirlpool Estate gas dryer dries but has a loud rattling sound when its in operation.
heatman101
Whirlpool dryer model #LGR 8620 pwo runs but only heats sometimes.
If you have a gas dryer...
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
1helpful
Have a Whirlpool gas dryer, model #LGR4634JQ2, that will not heat anymore and has a rattling noise every now and then. Any ideas?
The rattling noise is maybe a sort of buzzing only more metallic? Sounds like the coils on the gas valve making it flutter. Causes are the coils and/or the ignitor.
Eric
2answers
Don't know if my dryer is gas or electric
the E in the model # means it is electric. It would start with LGR if it was gas.
Dryer no heat but runs
WHAT IS WRONG WITH YOUR DRYER?
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE:
2answers
Gas dryer with no heat
check the ignition might be a glo-bar element or a maintained high voltage spark module. once there is a pilot a flame rod or a millivolt generator opens the main valve for fire.
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
