HDMI 3 goes out after about 45 minutes into dvd. It is the HDMI 3 channel that is bad. Are there separate circuits or is everything on a master board?
Try by update the EDID. Contact any service technician.
Gopakumar Gopalan Google
Testimonial: "An incorrect EDID wouldn't let the channel work fine for the first 45 minutes. It most likely is a weak semiconductor in the HDMI 3 channel. My original question-----is HDMI 3 a separate circuit or part of a master board?????"
SOURCE: Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
