We can't supply instructions on how to replace the switch, as this should only be carried out by a Dyson engineer. If you feel the switch needs replacing, please get in touch with us directly so we can provide further assistance - you can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
in many of these remote controlled lamps you cant use the new spiral light bulbs .. you can only use standard incandescent lights .. if thats not the trouble then you may indeed have a bad controller (in the fan) .. there is probably at least a 90 day warranty maybe as much as 3 years .. make sure the wire nut power connections are secure inside the fan.. if one of the the wires in the fan are not making contact then you will see a similar problem .. once in a while i have seen strong external RF signals interfere with the controller but thats rare and usually doesnt last long ..
i would : 1. check all the connections .. 2. replace the light bulb to make sure its not flakey or the wrong type .. 3. try to get the fan replaced in warranty ..
Make sure that both safety switches are engaged (front and bag area). If it is still not working, than could be the cord or ON/OFF switch. How to replace the switch look at detail instructions on our website: http://www.goodvac.com/kb_results.asp?ID=18
If you need any parts or supplies for your Kirby vacuum cleaner you can buy them on our website: http://www.goodvac.com/
2.How come it continues to rotate? Motor armature consists of multiple coils and just some of them burned so even though it keeps spinning it does not function properly.
3.Do I need to replace the armature? We have switch replacement instructions HERE and they will take you as far as accessing the motor. We do not have motor assembly instructions yet but if you get that far - motor is not that hard to reassemble. You may have to spend some time getting tolerance ring back in and make sure you install finger spring properly.
